HTP WT 960P
  • #36636
    machineman
    Does anyone know if these 3 phase mods part number C00143069 need configuring or they a simple swap over . The one we are going to wont stop filling.m
    #251782
    helo_75
    nope, youll need to fit an eprom to it!
    ok, here comes the hard part
    depending on which variant it is, theres actually 2 boards for that machine,, and more than 4 eproms
    mitigating factors? hot and cold fill or just cold fill? 2.7 software or 3.5? motor stack is another thing they mention (50mm or 45mm)
    to be more precise (and believe me it does matter ) , the production code woud be more helfull (on the sticker on the rear in brackets)
    and the production numer off the sticker inside the door, and the serial number
    sorry to throwe a spanner in the works, but fitting a pcb on its own wont work
    #251783
    machineman
    Re: HTP WT 960P
    serial 711270240 we are fitting eeprom COO145272 .M
    #251784
    Re: HTP WT 960P
    machineman wrote:serial 711270240 we are fitting eeprom COO145272 .M
    😯 That should work fine if you fit it to a Fridge Freezer. 😉
    That eeprom is for an FF40.
    Module is correct.
    As helo_75 says, you really do need the commercial code. Also is it hot & cold or cold fill only, welded or screwed drum?
    EDIT. Eeprom is either a C00203260 (3.5 software cold fill) or a C00193722 for motor with a 50mm stator stack.
    #251785
    machineman
    whoops sorry got my jobs mixed up.m
