hvr ab130
  • #25607
    machineman
    how do you change the paddles on the drum we have to give an est on this job ,are they the same as hpt /zan or is it a drum out cheers .m
    #206681
    helo_75
    Re: hvr ab130
    assuming the paddles are out…
    lie machine on side, remove sump, u can fit 1 screw into the paddle
    if the paddles still in its attatched by 2 screws, remove 1 by goin in thru sump, then break the other off, by woteva means possible( short shafted hammer works well)
    then refit with 1 screw, otherwise is drum out
    hope this helps
    #206682
    machineman
    sounds like good advice to me. thanks
