Re: Hygena 8224 does not heat water
Thanks, we suspected that may be it. It sounds easier than it looks.
The wires go around the hinge in a flat black plastic wrapper – does that unplug somehow? Or do we have to remove covers until we can see the ends of the wires, and then check continuity from the ends?
Can you identify the most likely one?
Having found one – is there an easy way of replacing it?
Is there any manual / diagram available that would help?
Thanks again
M
