Re: Hygena AE6BMS – Replacing light bulb
oh i see you are trying to replace the whole lamholder
take back off oven
disconnect wires
from the back, keep pressure on the old lampholder with one hand. with the otherhand using a small screwdriver push each of the barbs in (triangular fins) till it pops through the hole
when old unit is out the new lampholder should only go in one way. take careful not of which way the terminal face as if you get it wrong the cables may not reach
