Hygena AHY3410 Grill doesn’t get hot
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hygena AHY3410 Grill doesn’t get hot
  • #101155
    mrruss
    Hi there, I am new to the forum so hope this is the right place to ask for help.
    Our old Hygena AHY3410 Grill doesn’t get hot even after changing the element. I am supposing that the selector switch may be at fault but can’t find a wiring diagram to test it against.
    Any help or suggestions greatly appreciated.
    #483575
    you wont need a diagram if the contacts are broken or burnt you should be able to see it
    you can also test eact contact with a meter making sure they close at the correct time
    add to this a lot of grill controls can also have an energy regulator as well and if fitted this can go faulty
