Hygena AHY801/2
  • #39473
    Death by donut
    Hi guys,
    back again with the dishwasher this time , it’s started chucking water out at the bottom of the door.
    It happened over night really , and the door seal seems to be still in pretty good shape. There was a blockage on the sink waste ( outside , now cleared ) someone put some fat down the plughole. Could this have affected the DW waste?
    It seems to firing more water around inside than usual I’m sure.
    any ideas?
    Cheers
    DbD
    #262527
    Re: Hygena AHY801/2
    AHY8101/2?
    Lower spray arm will have a split seam. P/no 31X9985, available HERE.
    You don’t even have to turn the power of for this one. 😀
    Death by donut
    Re: Hygena AHY801/2
    Cheers for that Penguin , you were spot on , I’ve glued it up for now but will order the part later on.
    Ta
    DbD 😀
    #262529
    Death by donut
    Re: Hygena AHY801/2
    Hi Penguin ,
    had a bot of trouble buying it , what is the Verified by Visa bit?
    Navigated back from it and it all went pear shaped.
    Could you find out if I bought it or not?
    Ta
    DbD 🙁
    #262530
    Re: Hygena AHY801/2
    Haven’t a clue – best bet is to email spares@ukwhitegoods.co.uk and explain what happened.
    Death by donut
    Re: Hygena AHY801/2
    ok will do
