Hygena ahy8101/2 leaking
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hygena ahy8101/2 leaking
  • #25345
    Popop
    Has anyone had a leaking machine? My wife’s has started leaking at the front on both sides. I’ve tried cleaning the door seals but no luck. Help please!
    #205513
    Re: Hygena ahy8101/2 leaking
    Check spray arms for blockages and splits, also freedom to rotate as a starting point. Is door pulling fully home at the top?
    Popop
    I gave everything a good clean and checked all parts. The door shuts properly and all seems normal apart from the leaking! I even cleaned behind the seals at the bottom. Little plastic pieces too!
