Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hygena AHY8102 Dishwasher help
- This topic has 8 replies, 5 voices, and was last updated 21 years, 3 months ago by
nh.
December 23, 2004 at 12:03 pm #7209
nh
ParticipantI put my Hygena 8102 dishwasher on to wash dishes before going to bed a couple of nights ago. When I got up it was still going through cycle 6 hours later but making a loud grinding noise. Initially thought circulation motor had failed.
Stripped out and removed debri from circulating pump housing.
Tested after rebuilding but still the same and not completing wash cycle from previous night. Reset heater as it had tripped, then realised the machine had no water in it. Filled up with a bucket of water and noise stopped, machine completed wash cycle. Tested again, machine filled up and started to wash. Continued through cycle then machine emptied all water out, noise from circulating motor started again and heater tripped. Looks like machine is not filling after its initial hot wash has completed and water drained. Manually filling from a bucket allows cycle to complete.
Can anyone supply a flowcahrt of wash cycle after pressing start button.
Any help would be appreciated to fault find.December 23, 2004 at 12:28 pm #121996Dave_Conway
ParticipantRe: Hygena AHY8102 Dishwasher help
nh wrote:Can anyone supply a flowcahrt of wash cycle after pressing start button.
I don’t think there is such a thing, but there is a wiring diagram tucked next to the timer, it may include a flow chart.
nh wrote:Any help would be appreciated to fault find.
Check for more blockages by the sounds of it.
December 23, 2004 at 4:25 pm #121997clivejameson
Hi nh
I agree with Dave…sounds like a water level control problem which is usually down to a mechanical blockage (food residues)Clive
December 23, 2004 at 5:30 pm #121998nh
ParticipantThanks for the info. I found the circuit diagram, not easy to locate as it was folded up to the size of a postage stamp.
I take it the water level is controlled by the pressure switch?
The circuit refers to a water valve, a regeneration valve and a rinsing valve, I can probably workout what these are but not sure about regeneration.December 23, 2004 at 9:16 pm #121999Dave_Conway
Regeneration is to do with the water softening process, no need to investigate anything in that area 😉
December 25, 2004 at 1:05 pm #122000nh
ParticipantDave/Clive thanks for the info.
I checked for blockage to the pressure switch, blew through tube and it was clear. Tried wash cycle again and this time machine overfilled. Wife got kitchen floor washed. Eventually managed to set pressure switch by draining all water out of machine reconnecting tube to pressure switch then filling to normal ‘sump’ level. Started cycle and machine completed full cycle. It has now done a couple of full wahes and is cleaning better than it has done for months. Once again thanks for the help, I was struggling until you pointed me in the right direction.Neil
January 25, 2005 at 8:36 am #122001admin
KeymasterRe: Hygena AHY8102 Dishwasher help
Does anyone know where I can get hold of an instruction manual for an AHY8102? I have cleverly managed to lose mine and need to investigate why it is continioulsy running through a rinse cycle despite my best efforts. Any help / advice would be greatly appreciated.
January 25, 2005 at 8:52 am #122002Dave_Conway
The manual will be available from MFI Extracare on 08457 959722.
Hope this helps.
January 26, 2005 at 1:24 pm #122003RobD
Sure does.
Many thanks.
