Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › hygena AHY8102 help?
- This topic has 6 replies, 4 voices, and was last updated 21 years, 6 months ago by
oliflick.
October 11, 2004 at 8:11 pm #6480
oliflick
ParticipantHi can anyone help please my wife ran out of dishwasher tablets and used washing up liquid now the machine is stuck in cycle and continues spraying i have tried a cold rinse but it has no effect thanks oliflick.
October 11, 2004 at 8:23 pm #117900Penguin45
ParticipantOli,
The machine will have been circulating foam instead of water, which will almost certainly have caused some sort of heater safety thermostat to cut out. Your machine will be stuck at the heat part of the cycle; the programme will not continue until temperature is reached, which it isn’t going to do!Get out as much foam as you can and try resetting to the rinse and hold programme, use it to flush out the machine.
Some safety stats are resettable, some are one shot devices.
Unless you are very confident in your abilities it’s engineer time. Whatever you decide to do, pull the plug first.
Penguin45.October 11, 2004 at 8:52 pm #117901oliflick
ParticipantRe: hygena AHY8102 help?
It only has two programs cold rinse and wash i got out all the foam and have tried both programs and it still continues to spray only, thanks for your help will try an engineer 🙂
October 11, 2004 at 9:02 pm #117902Penguin45
ParticipantCheck the Directories section for a UKW engineer in your area, or stick your postcode up and some-one will pick up on it!
Penguin45.October 11, 2004 at 10:18 pm #117903eastlmark
ModeratorRe: hygena AHY8102 help?
That dishwasher uses a odd mechanical timer arrangement that needs to be carefully re set by an engineer (its not actually in the door, so dont go looking there). The heater re set is also well hidden.
March 17, 2005 at 11:40 pm #117904admin
KeymasterRe: hygena AHY8102 help?
Oliflick, I got the exact same dishwahser (AHY8102) and had exactly the same problem (put washing up liquid in). I rinsed out etc, etc and found that it still would not complete it’s cycle.
The answer I found was to bring the dishwasher out from under the kitchen unit, obviously disconnect the mains and watch you dont put too much stress on the water supply.
Then take off the right hand side of the dishwasher (large panel). Open the door and there is 2 screws, remove these. There are another 2 screws under the door and then there are three screws at the back. Lift the side panel and this comes off.
This dishwasher has one safety resettable thermostat. This is the on the bottom right hand side of the unit (looking from the front) and is easy to spot as this is like a little red nipple. There is only one of these in this unit so you can miss this. Press the little red blighter down and hey presto, it resets and all is fine.
What I did to mine was to first empty the washer using the drain timer setting at the front bottom of the machine. There is a black cover under the door, held on with 2 screws. If you set this to the 12 O’clock position this empties the unit.
Simple, it works, believe me, I did this …….
March 18, 2005 at 12:28 am #117905Penguin45
Good input, thank you. All readers of this post be aware that the procedure described MUST be performed with the power OFF.
Moderator. -
