Hygena AHY8122
  • #21874
    DentedPorsche
    Hiyas,
    Got a problem with one of these. Not heating the water. Have tried changing the bank of stats but no joy. Don’t know this machine at all and wandered if there was a common problem.
    Element is fine and meggers ok. There is a live supply to it but appears to have no neutral.
    Anyone have a wiring diagram for it? Any advice on repair?
    Thanks, in advance, for any help.
    Brian
    #192851
    cab
    Re: Hygena AHY8122
    ther is a toc at the back pokes thru tub between element most likely that, if customer puts large pans over that area it stops the water taking heat away from element toc trips, early ones are manual reset.
    cab
    #192852
    DentedPorsche
    Re: Hygena AHY8122
    Thanks Cab. I’ll check that out when I go back to it.
    Brian
