I have a hygena dishwasher which has recently decided to fill very slowly. It will fill but takes approx 10-15 mins during which time water can be heard going into machine at a trickle. Has refused to fill at all once also.
Any help for this or is it a tip job? Machine old and as i got from freecycle i dont mind spending £50 or so on it if it can be fixed as been decent machine for the last year.
Re: Hygena APL 8124/1 Not Filling / Filling very slowly
its probably the inlet valve which is around £50 retail
but before you jump in and order check water supply its not the first time i have found a kink in a water pipe the works for a few years then stops the water
take water pipe off and make sure you have a good water flow to machine
