Hygena APL 8224/1 Overfill
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hygena APL 8224/1 Overfill
  • #61888
    brian911uk
    Initially my problem was that it didn’t fill so removed the fill valve and powered it to test if I could blow through valve – I couldn’t so guessed this was fault. Now I have fitted new valve (which didn’t include new overfill device) it fills but now never stops (I did operate the first time without the pipe to the overfill connected :boops: ). On further examination I think that the attached overfill/diaphragm should stop it but can’t get it to operate. Is there a recommended setup for diaphragm i.e. can it be primed or something or can someone suggest how I can test operation. (can’t see where other end of overfill diaphragm pipe is connected either)
    TIA.
    #347937
    Re: Hygena APL 8224/1 Overfill
    Hi Brian,
    You need to use the correct valve on one with an overfill or pressure sensor mounted on it, for that model it’s this one and nothing else will do in its place I’m afraid.
    A standard valve will not operate correctly.
    HTH
    brian911uk
    Hi K,
    Thanks for the reply. I have the valve you suggested. It does not come with the additional piece which I assume is the overfill sensor. I have used the original one but as I said I did start it first time without the pipe which is connected to this in place. Now when it is connected it does not stop the fill and I am not sure what if any is the procedure to setup. Any assistance gladly accepted.
    Brian
    #347939
    No, so far as I am aware there’s no setup. I sure never did any, just swapped the valve out and they just worked. 😕
