Hygena APL 8224 doesn’t heat up
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hygena APL 8224 doesn’t heat up
  • #7827
    davidl
    Hi can anyone help with this? I have a Hygena APL 8224/1 dishwasher no problems the last 6 years. Now when it washes it doesn’t heat up. What is the likely cause? Many thanks
    #125340
    Re: Hygena APL 8224 doesn’t heat up
    This is a Brandt made dishwasher, so the most likely culprit is the safety thermostat has tripped.
    There are problems with this. Firstly, the reset is inaccessible, secondly it will have tripped due to the machine underfilling. This is a very awkward one to sort out – I would seriously recommend getting some professional help. Check in Directories or Repairs@ for a UKW repairer in your area.
    If you’re going to have a go yourself, pull the plug first. :plug:
    davidl
    Thanks for your swift reply…I will have a look for a repairer in that case!
    #125342
    davidl
    After some months of tedious washing up I thought I should get this sorted!
    An engineer has examined the dishwasher and told me it needs a new heating element – but these seem to be hard to find. Can anybody help?
    Many thanks
    #125343
    NWAR
    David
    Part number for the element is 31X6062 and retails at around £29.99 excluding VAT & P+P from MFI on 0845 7959722.
    Craig
    #125344
    davidl
    Blimey that was quick!
    Many thanks Craig
