Hygena APL3416 strange fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hygena APL3416 strange fault
  • #40127
    Ally
    Evening Troops
    This is slightly strange in that after a while the oven temp light stays on but the element is not supplied with 240. Also the element fan does not work although the cooling fan continues to work. The thermostat is heard clicking at around the right temp when moved up and down and the temp light stays on irrespective. Every time I get there and start to open the back the dam thing starts to operate perfectly. Unfortunately I do not possess a manual so hoping someone can shed a light and possibly a part No. I suspect a block situated in beside the thermostat with four wires coming out but cannot find it listed in any suppliers catalogues. Thanks Ally in Glasgow.
    P.S I know this is an old oven although the person involved keeps it in immaculate condition and is loath to part with it.
    #264842
    Re: Hygena APL3416 strange fault
    Ally, that one has a door swtich, suspect bad connection or burn out there. Its in the left side panel (when viewed from the front) can zax you a diagramm if wanted.
