Hygena APL8124 Ovefilling?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hygena APL8124 Ovefilling?
  • #20951
    navillusi
    Hello
    I have a 7 year old hygena APL8124 Dishwasher which has so far given reliable service – until now
    When filling at the start of the cycle, water can be seen leaking from under the door. I have cleaned the bottom of the door to remove gunk etc but still leaking.
    What I have noticed, however, is that the fill time seems to go on for a long time, and that the water level reaches a level higher than the bottom of door – is this normal?
    I have been looking for some sort of level detection device at the bottom of the m/c thinking maybe it is fouled up, but cannot find.
    Any ideas please?
    Regards
    Ian
    #188895
    Re: Hygena APL8124 Ovefilling?
    This is one of the early Brandt-built machines sold under the Hygena name. To be honest, it’s a complete swine to work on – I’m a pro and I struggle with them. The pressure switches are round with a skinny air hose running to them. Simple fix is to blow back through and see if it makes a difference. If it doesn’t, follow the hose and start dismantling and cleaning.
    Assuming that I haven’t frightened you off, pull the plug first.
    Otherwise, click the link below for a UKW engineer in your area. I hope you’re not in N. Leeds……….. 😀
    navillusi
    Thanks for your help
    Turns out that the fill switch is on the side of the machine, actuated by a float mechanism.
    Wobbled the float about for a bit and the machine is now behaving itself
    Incidentally, I found a schematic drawing inside this machine, if it is any use, I will scan it in and post, let me know
    Regards
