Hygena APL8224/3 not empyting
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hygena APL8224/3 not empyting
  • #12502
    Wattie
    I have a Hygena APL8224/3 which, after, heavy use at the weekend has stopped empyting properly.
    I’ve cleaned the filter at the bottom and run through with dishwasher cleaner a couple of times but it’s no better.
    Grateful for any ideas on how to fix.
    #149947
    Dave_Conway
    Re: Hygena APL8224/3 not empyting
    Check the drain where the waste hose connects first of all, they block there quite often.
    Apart from that, it’s engineer time to be honest, possibly the pump has failed or a blockage internally somewhere. Try Repairs@ for one 🙂
    If you do decide to have a look, please power off first :plug:
    #149948
    Dabchick
    My dishwasher blocks occasionally. I’ve had a lot of success clearing it with a normal plunger – might work for you as well.
    This is not a technical reply !
