Hygena APM 8702 not emptying water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hygena APM 8702 not emptying water
  • #24859
    colossal
    The machine is in rented accomodation & the tenants never cleaned the filter. The filter has now been cleaned, it was thouroughly blocked, it still doesn’t empty.
    I have ordered a new pump as I suspect it is burned out. Is this most likely the fault or should I check anything else ?
    #203561
    Re: Hygena APM 8702 not emptying water
    If you can’t actually hear the pump running, replacement is orobably your best bet. If you can hear it running, you have a blockage elsewhere, probably in the hose coming down to the filter.
    Power off if poking about inside.
    colossal
    Thanks Penguin
    The pump can’t be heard so hopefully the new one will fix it……
