The fan and light switch seems to have brokenthis hood I inherited. Is there a replacement hood I could use, or is it possible to still get these ?
THanks
Dave, Thanks, I’m not sure what’s broken exactly – nothing works so I’m looking to replace the whole thing. There’s no obvious signs of failure and I assume it’s the switch itself. The switch has the wires soldered to it for both lights and fan. Clive
I would check other things first in that case if the whole thing appears dead.
I would imagine you have just moved in to a new home and this hood was already there when you say inherited ?
I’ll wager that the previous owner has switched the isolation switch off for it, have a look on top of the cupboard the hood is installed to for a switch of some sort 😉
😀 Nice try ! The thing was working (apart from the hood operated over-ride switch) but has now stopped. Although I can track power into the main switch, I get no further….it’s not coming out of the other side either to light or fan. I did move into the house and it was there then, so it’s age and history are indeterminate ! Clive
