Hygena APP2500, stopped working, lights work, no fuse problems
unit started working intermittently, pressed switch on/off a number
times for it to work.
Is it possible to replace a single switch / or swap switches around until
I get a complete switch unit.
I have stipped switch unit down, main switch had shorted out, burnt part printed circuit away, I rebuilt circuit by resoldering track back, and all is ok for now.
you need a new switch pcb assembly p/n W0000051 (was W0000025) which has uprated switches on it. it needs to be soldered in place. spares@ukwhitegoods.co.uk will be able to supply it.
