Hygena Dishwasher
  • #12513
    tiger2403
    Please can someone help. You have moved house and inherited a Hygena Dishwasher. There are no distinguishing marks to indicate the model number and we have no instructions on how to use ( putting in rinse aid and tablets for instance ).
    The brief description is a standard size ( not slimline ) and has a dial on the left as you look at the appliance. This dial has three programmes indicating which wash to use – we have been using no 3
    Can anyone help.
    Cheers
    #149997
    NWAR
    Re: Hygena Dishwasher
    The model number should be on the rating plate located on the inner frame of the door. It will be in the format APL**** AHY**** or ADP**** where * represents a number
    Craig
    #149998
    tiger2403
    Craig, thanks a million its a APL 8124 / 1
    Now all I need to get is the manual
    brent
    #149999
    Dave_Conway
    You’ll need to phone MFI for that brent.
    08457 959722 🙂
    #150000
    tiger2403
    done…. ordered… be here in the next 5 / 7 working days
    thanks every one 😀 😀
    #150001
    MELNI
    DOES ANYONE KNOW WHY THE INDESIT D63 FILLS UP WITH WATER IN THE BASE.
    JOHN ,ESSEX
    #150002
    clivejameson
    Yes John….
    If by the base you mean the inside where you load the machine then there is either a back-flow from the waste connection, or the inlet valve is not shutting off correctly.
    If you mean the ‘under-tray’ of the machine then quite simply you have a leak somewhere, this could be from several sources ranging from very minor to write-off really.
    Best bet is to have an engineer look at it for you if you are unsure how to proceed. Have a look in Repairs@ (the big red tool-box on the left) to see if there’s someone near you.
