hygena dishwasher
  • #38973
    kailogan
    just got given dishwasher with model no.ahy8122, it come with a part in witch i was told was problem.( thermo limiter assy) changed that. but have noticed that the sump fills with water but does not empty at all.not allowing it to continue its wash.the float does its job so ive sank that down and then it carries on with its program.ive done as much research as i can on how dishwashers operate but now ive come to a dead end.many thnx brian and tess.
    #260528
    Re: hygena dishwasher
    kailogan wrote:starting to rule out the problem i have.lol. its now in constant empty pumping motion lifting the float switch stops it but still no further on the progams. could it be the presure switch? also there dont seem to be any form of the machine draining it self from the sump very bottom of the machine. is this correct as ive never seen a dishwasher in action. ive poured a pan of water into drum and it pumps it straight back out.ive changed the height of the outlet pipe and still no differance. any help is better than no help many thnx. 🙁 oh by the way its a hygena model ahy8122, thnx.
    Added to keep it all together…..
    Are you telling us it doesn’t circulate the water? No circulation will trip the limiter – which can be manually re-set by pressing the red button.
    Beyond that, I have no idea what you’re asking us.
    kailogan
    where is the lil red button please as its not ciculating the water at all it,sorry to be so vague but i was hoping to get it sorted asap before i have to go back to work. many thnx
    #260531
    kailogan
    still cant find how the water is removed from the bottom tray of the unit where the wiring and pump unit is.also discovered its not creating enough vacum to trigger pressure switch. ive phoned a few local repaires shops but no one can get the parts. on this note shall i give up and declaire it dead????
    #260532
    kailogan
    ok and the verdict is 2days of tweaking testing and wet knees and elbows over and over again has resulted in kicking a huge dent in the side of it and going out and buying a new machine.we thought how nice it would be to a have a luxuary and even better if it was given to us, oh how wrong could we have been! well untill next time my friends although i havnt made any on here yet though. CYA !!!!! 😆 😆 😆
