HYGENA Freezer APM6222 not cutting out.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum HYGENA Freezer APM6222 not cutting out.
Viewing 1 post (of 1 total)
  • #53119
    OPTICGB
    HYGENA APM6222
    I had a problem with the warning buzzer going and having to keep boost freezing, then the motor stopping altogether.
    I purchased the new thermostat circuit board and put it in place. All the lights worked, the motor ran and the freezer appeared to work OK. Now with just the green light on and the motor running, the motor won’t cut out. I can turn the power off and on manually to cut the motor. The motor stays off for a period of time before cutting in as you would expect but then won’t cut out again. The cold setting is mid way between min and max.
    Has anybody got guidance on my next course of action? It would be most appreciated.
    Thanks, OPTICGB
