Hygena hob control failed (again)
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hygena hob control failed (again)
  • #23904
    Phil_s
    Hi there,
    I have a Hygena Hob AHY1120. I originally fitted one about 7 years ago. After about 5 years this failed (the control knob to the largest ring stopped turning). After a while I replaced the hob with another exactly the same. Big mistake because now after just two years I have exactly the same problem. Is there anything easy I can do about this? Is this a common fault with these hobs? If I have to replace, is there another more reliable hob with the same footprint (I don’t want to have to replace the worksurface)?
    Any help welcome.
    kind regards
    Phil
    #199800
    Re: Hygena hob control failed (again)
    Sorry, we cannot advise.
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=16259
    Phil_s
    I presume that this is because it would need to de dismantled and I am not allowed to do that. If so, that is fine. Can you tell me if it is repairable by an engineer, or do I just cut my losses and replace it?
    Kind regards
    Phil
    #199802
    msappliance
    Yes an engineer should be able to repair this fault.
    #199803
    wsts
    Its an easy repair, at the worst the tap only needs regreasing,have sorted this problem loads before when I used to do their warranty work with stoves.
