Hi everyone.
I have a Hygena hood AP2300 that stopped working – lights and fan! Have replaced light bulbs to no avail. I never had an instruction manual with it so am in ignorant bliss, I wondered if its a fuse gone- if so where is it, what size and where does it go!?
Indeed the first thing to check is the fuse as you rightly suggest 🙂 It is likely your cooker hood has a seperate fuseable switchbox somewhere close to it, where it is plugged in. Either in a cupboard or above the wall cupboard on the top of a cupboard. Maybe even a seperate RCD trip switch has failed at your mains fusebox :con:
Your need to source this first and check it out 😉
