I need the plastic button and also the switch the button sits on, the one I have has seized so when you press the button the switch does’nt move so no gas ignition. The switch is fixed onto the hob by a small bolt.
The problem I’ve got is the original owner of our house left no manuals for the appliances, would you know the best way to get to the model number on the hob ?
Yeah Mike, you’ll have to pull out the oven and it’s on the rating plate on the underside of the hob. There’s no other way really and user manuals are not to be trusted for model numbers as they more often than not cover a range, not a specific appliance.
