Hygena oven not working but clock is working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hygena oven not working but clock is working
  • #90958
    Heater
    Hygena oven was on and used for 40mins at 180 then turned of for 10 minutes and turned on to use the grill then switch off and then tried to put oven on but the whole thing is dead the light is not even coming on but the clock is on a working fine any ideas what it is
    #446591
    Re: Hygena oven not working but clock is working
    You’ll need to give the model number to get anywhere as there’s slews of them, all different.
    Should be inside the door or on the top panel, you may need to pull it out a bit to get to it in that case.
    Heater
    Its AE6BMS
    #446593
    Most likely is a faulty limit stat, this one:
    http://shop.ukwhitegoods.co.uk/32009198 … ostat-140c
