Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Hygena OvenStuck on Automatic
- This topic has 5 replies, 3 voices, and was last updated 17 years, 8 months ago by
PGTips.
July 30, 2008 at 10:19 am #38400
PGTips
ParticipantI have a Hygena Oven Ref APL 3418 and the programmer is stuck on “Auto” Occasionally it will start to flash and when “Manual” button is pressed to reset it just jumps back to “Auto” setting.
Is there a simple solution of bypassing “Auto” and just have the oven working on “Manual” ?July 30, 2008 at 10:41 am #258757helo_75
Participantonly if your good with a multimeter and can figure out which bit switches what and how
not impossible, just a but tricky
plug out if your gonna have a go!
July 30, 2008 at 1:29 pm #258758karv
ParticipantRe: Hygena OvenStuck on Automatic
only like 2 to 4 wires going to most timers some live some neutral never had that fault myself. don,t think new timers are that expensive on most ovens some are tho.
ps its not something silly like the clock or pannel have moved out of alinment and rubbing on the button keeping then pushed in ?July 30, 2008 at 3:13 pm #258759helo_75
karv wrote:only like 2 to 4 wires going to most timers some live some neutral never had that fault myself. don,t think new timers are that expensive on most ovens some are tho.
ps its not something silly like the clock or pannel have moved out of alinment and rubbing on the button keeping then pushed in ?wow, thanks for that!!
i can tell how many timers you’ve bought… ive changed loads of timers in my 22 years, but hey, what would i know
July 31, 2008 at 11:06 am #258760PGTips
Participanthelo_75 wrote:only if your good with a multimeter and can figure out which bit switches what and how
I think it’s time to phone my brother. I’m not too good with electrics or water.July 31, 2008 at 11:20 am #258761PGTips
ps its not something silly like the clock or pannel have moved out of alinment and rubbing on the button keeping then pushed in ?Thanks for replying, unfortunately it’s not the simple answer. Nothing sticking with regards to push buttons.
Any ideas on how to remove the whole timer if it’s viable to replace.
Thanks again
