Hygena Select 610 Oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hygena Select 610 Oven
  • #18522
    brotherpipi
    My oven model is AHY3300. Stopped working when I turned off at wall socket (switched off wrong socket!). Started working after twisting a few buttons – must have been a fluke cos it’s happened again but I can’t get it started now.
    Not sure if the clock display is flourescent because it doesn’t tick or seem to be working at the moment. (I’m sure it was last week when it started up again, but I don’t think it ever worked before that when the oven was working fine).
    I have hand symbol showing (at 9 o’clock).
    The red hand moves with the hour hand on clock when I’m changing the time. I can’t seem to move it separately (even by pulling out top button and twisting). You can probably tell I’ve just been twisting knobs hoping that something triggers the oven on!!!
    Any ideas?
    Paul
    #179319
    Dave_Conway
    Re: Hygena Select 610 Oven
    brotherpipi wrote:I have hand symbol showing (at 9 o’clock).
    It seems to be on manaul then which is OK.
    It may be that the supply to the cooker has failed if the clock isn’t working either and the whole oven is dead.
    I think an engineers visit is advised to be honest to check the various possibilities, try the repairs@ link below 🙂
