Hygena Select APL 8224/1 Heating Problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hygena Select APL 8224/1 Heating Problem
  • #27920
    oaksoft
    Hello,
    I have a problem with my integrated Hygena Select 8224/1 dishwasher.
    We have had problems with dishes coming out dirty and I’ve discovered that the water is not heating up.
    How do I go about troubleshooting this?
    I am a novice on this.
    All help gratefully received.
    #216091
    Re: Hygena Select APL 8224/1 Heating Problem
    Forum rules – top of the forum. We will not advise you how to do this on a blow by blow basis.
    That said, if you have a multimeter, you should be looking for resistance through the heater and continuity through the heater and thermostat circuits.
    If you’re not sure how to do this, please use the repairs@ linke below for a UKW engineer in your area.
    Power off if you are going to investigate.
