Home › Forums › Public Support Forums › Spare Parts Help › Hygena Turbo oven glass
- This topic has 14 replies, 5 voices, and was last updated 21 years, 3 months ago by
admin.
January 12, 2005 at 7:12 pm #7437
KeymasterHi,
We managed to shatter our oven door glass during a houseparty last year and have had no luck finding a replacement, mostly becasue we haven’t got a model number. It was either on the glass (which is now in a thousand bits) or has rubbed off the front. The landlord claims not to have the manual (and we certainly don’t), it’s also not on the inside as far as we can tell.
It is labelled ‘Turbo by Hygena’ and is a standard-looking four hob, oven and grill combined, electric unit. The glass looks like it should have dimensions approx 59cm*46cm (W*H) and covers the whole front of the oven, with the handle attached through the glass.
Can anyone advise as to a replacement? If any further measurements or identifying marks are required, let me know!
Thanks,
Dan.
January 12, 2005 at 8:41 pm #123271kwatt
KeymasterDan,
Without a model numer it’s going to be nigh on impossible to replace, but if you can get some photos sent then we may be able to identify it for you. 😉
January 17, 2005 at 11:26 pm #123272admin
KeymasterRe: Hygena Turbo oven glass
Hi, sorry for the delay,
I’ve uploaded three photos of our admittedly very dirty cooker to my webspace:
http://www.dnr.pwp.blueyonder.co.uk/cooker/cooker1.JPG
http://www.dnr.pwp.blueyonder.co.uk/cooker/cooker2.JPG
http://www.dnr.pwp.blueyonder.co.uk/cooker/cooker3.JPGHope this helps in identifying it!
If you need anything else, don’t hesitate to ask,
Thanks very much,
Dan.
January 18, 2005 at 12:10 am #123273Penguin45
ParticipantDan,
Ignore the hob, it is a separate item. If you check around the door opening, you should find four screws. When removed, the oven can be slipped forward and the other rating label will be revealed – on most of them it’s on the top of the oven box but on a few it’s on the back. You’re looking fora number starting “ADP—-” or perhaps “APM—-“. I’m afraid that without it you have virtually no chance of resolving this.Regards,
Pengiun45.January 18, 2005 at 7:42 pm #123274admin
I took the oven out as you suggested and found a rather dusty label:
Hygena
Serial No: 02237356 [Model 2]
Model: AHY3220 [White Mod2]2.05kW 220-240V ~50Hz
No ADP or APM but an AHY. Is it possible to get a replacement front glass panel (not the inside glass, the exterior sheet)?Thanks very much, I would never have tried looking there!
Dan.
January 18, 2005 at 8:38 pm #123275kwatt
KeymasterHi Dan,
We can pick it up from that information no problem at all. Get back to you in the morning hopefully with more information. Or, even better, if you drop an email to spares@ukwhitegoods.co.uk Dave will answer it for sure in the morning.K.
January 18, 2005 at 11:31 pm #123276admin
I’ve e-mailed a request for a price to that address.
Thanks for the prompt responses guys!
Cheers,
Dan.
June 28, 2005 at 9:11 am #123277admin
I have managed to do pretty much the same thing to my hygena oven except I have managed to break both the inner and outer glass.
My oven looks the same as the one in the pictures, in colour and lack of oven door, expect it only has the dial on the left.
I have a manual (which covers a range of cookers) and i’m guessing from that i have a AHY3120 does that sound right ?
cheers,
neil
June 28, 2005 at 9:35 am #123278Dave_Conway
ParticipantRe: Hygena Turbo oven glass
neilR wrote:I have a manual (which covers a range of cookers) and i’m guessing from that i have a AHY3120 does that sound right ?
That is a good model number but I would be best to make sure before you ordered anything, details for this model are:
Inner door glass £36.30
Outer door glass £55.39
Postage £7.95All inc VAT. If that is your model and you need to order, an email to spares@ukwhitegoods.co.uk please 😀
June 28, 2005 at 10:11 am #123279admin
OK, i follow the advice above to find the model number tonight and email you direct.
Also would you be able to supply the black goop that seems to stick it to the frame ?
cheers neil
June 28, 2005 at 10:13 am #123280Dave_Conway
The metal parts glued to the outer glass will come already glued in place, no gloop required 😀
June 28, 2005 at 11:03 am #123281admin
Are you sure you guys are in the trade, aren’t you supposed to suck your teeth and say ‘i dunno mate, the problem is see; that you got replace the whole thing and once you’ve done that you might well replace the hob …’
thanks for the help dave expect a email tommorow 😉
neil
November 26, 2015 at 2:38 pm #123282NeilS
I have the (I believe) the same model as described in this thread Model: AHY3220 [White Mod2] but rather than having shattered glass, the inside glass has come adrift at the top of the door, as the plastic that holds it in place has snapped both sides.
These appear (see photo) to just slot in (well they pulled out anyway) and look like they would hold the glass in place, if I could acquire some without the snapped part and reinsert them.
Are they possible to obtain?
Thanks Neil
November 26, 2015 at 2:47 pm #123283kwatt
http://shop.ukwhitegoods.co.uk/osstecgl … -strut-cap
http://shop.ukwhitegoods.co.uk/osstecgr … -strut-cap
November 26, 2015 at 2:57 pm #123284NeilS
Wonderful – All ordered – Thanks
