I am sure it is easy when you know how HPT WF541P
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries I am sure it is easy when you know how HPT WF541P
  • #52789
    Electricmalc
    One thing I hate is customers having a go at a repair, find they can’t do it and then give me a call.
    Door handle broken, they had purchased a new one but after taking the door apart they could not fit it.
    I must admit I have never fitted a new handle to these machines.
    There was the handle, door latch, latch spring and latch pin on the floor.
    I assembled them in the normal way with the latch spring pushing against the latch, then fitted the pin and handle into the half door frame.
    The door handle feels very loose as if there should be another spring or plastic moulding for it. Customer says there was no other spring, and a search on connect for that model doesn’t show another spring.
    The machine will work if you hold the door shut, but customer not too keen on doing that. 😯
    Has anyone had any problem with these before ? 😕
    28 years in the trade and I am stumped.
    Only another three and a half years to go. 😀 😀 😀
    Malc
    #313130
    nospin
    Re: I am sure it is easy when you know how HPT WF541P
    is the inner frame broken? Sounds like the latch has nothing to push against???
    #313131
    loopey
    weak spring ? have bent a few that have gone weak , may be strained by customer ..
    #313132
    jason1970
    Good chance it’s the spring. It has two ‘arms’ they bend and eventually snap. Spring can be bought seperately or the handle/latch etc as an assay. Sorry don’t have pt nos to hand.
    #313133
    Electricmalc
    Went back today, and within 3 minutes sussed out I had the latch spring legs in the wrong place. Never too old to learn, thanks for your replies.
    Malc
    #313134
    LJDomestics
    yes they locate in the little rounded grooves at the front….. sometimes if u look very very closely u will see very small indentations were they have been pressing into the plastic.
    #313135
    Electricmalc
    Not the “normal” place you would expect them to go is it.
    Malc
