i have a problem with a stoves m/o stat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries i have a problem with a stoves m/o stat
  • #36549
    TELL
    i cannot id this stat orig pt no. is 082359300, and it changes to 082558001, from connect. they are listing the part obselete. how do i post photos onto the ukw site, for help.
    TELL..
    #251461
    Re: i have a problem with a stoves m/o stat
    082359300 is showing in stock at Masterpart.
    I use Photobucket to upload piccies – you can do a clicky/link thing to post on UKW.
    TELL
    does this stat have 3 contacts no’s 3-2 which is for the element, then a contact no. 5, which switches the fan on constant. also printed on the side of the stat it has EGF 205 ?.
    TELL..
    #251463
    No idea – no pic. Just put the number in and it came up as in stock.
    TELL
    thanks. will check with masterparts.
    TELL..
    #251465
    scots
    Have had real problems getting the correct sta for my Stoves.
    The one I need is marked EFG206 although Connect have sent me two incorrect ones.
    One is marked EFG205
    It has connections 2 3 and 5
    I will be sending it back but if you can’t get one elsewhere I can send you this one at cost which was £33.06 plus vat.
    Brian
    #251466
    TELL
    thanks brian,
    just got to cost out an est, for customer, other parts needed .did get correct info off m/parts, they have them. dont no what connect are playing at, they have listed efg206 as a direct replacement. will let you know hopefully by wk/end.
    TELL..
    #251467
    TELL
    Brian
    thanks for the offer. cust now going for another cooker.
    TELL..
