Re: I need a compact wet and dry vacuum cleaner.
this post flags up a few problems for me
1 a wet and dry cleaner cannot do both at the same time. if you set it up dry the unit uses filters or bags to catch the dust. if you set it up wet you remove the filters as the water stops the dust and the filters would get wet and water would get into the motor
2 from reading your post it seem you want it to handle wet just in case you children spill something so no that wont work
also you state 6 gallons, that’s a lot so it would be a big unit
