I need a new oven.. help
Home Forums Public Support Forums Help And Support Cooker And Oven Forum I need a new oven.. help
  • #95679
    BarryChall
    My existing oven which is a New World 61MF is not heating up properly. The bottom seems to not be working. I am getting heat from the top tho. So I can cook but not very well.
    I have decided as I can’t fix it I would just replace it. The problem is they don’t make them anymore.
    The hob which is a GHU60 is ok. It still works. So I will keep that.
    Any ideas what sort of replacement i can get. It is stainless steel so needs to match the hob.
    Also is it just plugged into the wall. And is it a case of unplugging the old one and plugging the new one in?
    thanks in advance.
    #461041
    If it’s a standard 600*600mm oven then you should be able to replace it with pretty much anything.
    BarryChall
    Hi thanks for this, are they all roughly the same size? I have seen a few different ones but they show slightly different dimensions.
    Also, do I just plug it into the wall.
    #461043
    They should be able to fit into a 600 x 600 x 600 space for a single built-in oven.
    Some are on a plug, some are hard wired to a spur.
    BarryChall
    I’ve picked an Econolux ART28755 60CM, have opted for no installation. Doesn’t say if it’s a plug in or not tho.
