Home › Forums › Public Support Forums › Buying Advice › I need a Pyrolytic double oven
- This topic has 22 replies, 5 voices, and was last updated 12 years, 4 months ago by
pete2848.
November 15, 2013 at 10:38 pm #78130
pete2848
ParticipantHi i need a Pyrolytic double oven, built in, in a one on top of the over oven configuration.
The only ones that i seem to be able to find are De Dietrich DOD1278X Double Electric Oven, Stainless Steel at http://www.johnlewis.com/electricals/co … /c80000462
All the reviews on the internet seem to slate De Dietrich appliances as being awful.
Can anyone help on what they think of De Dietrich and hopefully suggest any other manufacturer that does this configuration.
Many thanks
Pete
November 16, 2013 at 12:18 am #404576kwatt
KeymasterRe: I need a Pyrolytic double oven
De Dietrich are not so bad although the parent company, Fagor, is currently experiencing some problems.
But, why do you need a pyro oven like that?
Pyro is okay (I’ve had two, one Smeg, one De Dietrich) but it’s not nirvana and you still need to clean, especially around the door as well as all the shelves. Plus, when you use the pyro function it stinks the kitchen out big time in my experience.
In all honesty, I wouldn’t bother and certainly wouldn’t pay the premium for it. I’d pay more for a top notch oven as I like cooking but, I wouldn’t for that one feature.
November 16, 2013 at 2:48 am #404577pete2848
ParticipantRe: I need a Pyrolytic double oven
Thanks, I am disabled and need a self cleaning oven, does any other manufacturer do this in a double oven version?
November 16, 2013 at 7:58 am #404578Martin
pete2848 wrote:Thanks, I am disabled and need a self cleaning oven, does any other manufacturer do this in a double oven version?
Several manufacturers produce self-clean (pyro) ovens but, as my colleague has said previously, they fall way short and are really not the answer you seek. In any case no-one has come up with a double oven with self cleaning top oven/grill. And they get just as messy if not more so and are a devil to clean at the best of times.
Far better instead you choose a double oven with catalytic oven liners. They self clean just as well, if not better, are a fraction of the price and can be cheaply replaced if necessary.
HTH?
November 16, 2013 at 8:14 am #404579pete2848
it does say that the De Dietrich DOD1278X Double Electric Oven,has a prrocleaning top and bottom oven cleaning system, is this not the case?
November 16, 2013 at 10:05 am #404580kwatt
Apparently it does, I did think like Martin that it would only be the main oven but it appears that the small oven is also pyro.
That being the case you may well find yourself with only one choice as it’s very unusual for both ovens to be pyro.
November 16, 2013 at 11:25 am #404581Martin
De Dietrich are a bit of a lemon though IIRC?
November 16, 2013 at 12:06 pm #404582pete2848
“De Dietrich are not so bad although the parent company”
thanks, which is true about them, good or rubbish?
November 16, 2013 at 4:30 pm #404583Martin
pete2848 wrote:“De Dietrich are not so bad although the parent company”
Well Fagor went into administration a short while ago though has since been rescued by another major brand (I think? though it’s a job to keep up these days.
Speaking personally I wouldn’t buy De Dietrich as they are nothing like the original French manufacturer of old. Nor would I buy self clean as they are unreliable to a finite degree. (but then I’m in the trade and see the rubbish that’s about these days)
November 16, 2013 at 4:35 pm #404584pete2848
thanks martin, what should i get?
November 16, 2013 at 4:39 pm #404585kwatt
As yet there is no news on what will happen to Fagor Martin. The workers in Spain had a sit-in the other day to try to protect the company.
Not much news from France.
Fagor Ireland has also filed for bankruptcy.
Where that leaves De Dietrich and Fagor in the UK is anyone’s guess.
As far as I am aware, no offers have yet been made for the company.
Which is why, whether I like Fagor or De Dietrich is irrelevant, it cannot be recommended as a buy until the future of the business becomes clear or, you get it at a knock down “too good to pass up” price.
November 16, 2013 at 4:42 pm #404586pete2848
could you recommend a brand that you think is good please.
November 16, 2013 at 4:59 pm #404587Martin
pete2848 wrote:could you recommend a brand that you think is good please.
HEREis a good example. (Note, it uses catalytic oven liners on both ovens – better option) 😀
November 16, 2013 at 5:12 pm #404588pete2848
thanks, i do like Bosch and wanted to get either a seimens or bosch, doe sthis system work the same as with enamel panels, my current model has side panes which absorb the fat, also does it have the panels all over so i dint need to clean any of the surfaces, many thanks for all your excellent help.
November 16, 2013 at 5:24 pm #404589Martin
You’re getting where I’m coming from Pete. With the self clean catalytic liners all you need to do is closely follow the manufacturers instructions and your oven and grill will stay clean all the while. Avoid excessive,fat spitting, cooking due to overheating and poor shelf positioning. Don’t ram the Xmas Turkey too close to the fan or the full English bacon close to the infra reds. All common sense stuff to be honest.
All the best! 😀
P.s. I clean the wire shelves every month with hot soapy and a foam backed scouring pad. 5 minute job.
