I need a Pyrolytic double oven
Home Forums Public Support Forums Buying Advice I need a Pyrolytic double oven
Viewing 8 posts - 16 through 23 (of 23 total)
  • #404590
    pete2848
    Re: I need a Pyrolytic double oven
    interesting that bosch say “Ovens with
    EcoClean liners and an EcoClean
    self-cleaning programme also
    reduce the amount of elbow
    grease you need to use to keep
    your oven in showroom condition –
    though not as effectively or
    as easily as the pyrolytic
    self-cleaning cycle. “
    #404591
    pete2848
    do bosch/seimens do a double oven with pyro cleaning for the main oven and not for the top oven i wonder?
    #404592
    pete2848 wrote:do bosch/seimens do a double oven with pyro cleaning for the main oven and not for the top oven i wonder?
    Yes of course. ( you really won’t let go of the pyro idea will you – hey ho?)
    Read carefully the spec on both web sites to realise which model does what.
    I’m out!
    #404593
    pete2848
    i cant do any cleaning so the pyro does look the best otion for me, ive researched it quite a lot with people always giving excellent reviews of the process being ver efficiaent and truly a complete self cleaning oven with no hard work at all altho i do understand that the glass and door will need to be separately cleaned, the units where the glass can simply be unclicked at the top and the three panes easily removed seem a good idea. i would preser a bosch or seimens as all my other appliances are that make and have been very reilable and long lived, im trying to search through the bosch double ovens to find one as you suggest, is you do have a specific reccomendation i would be very grateful or any advice as the best one to get.
    #404594
    don
    The majority of manufacturers only fit pyro to single ovens probably due to the higher price a double oven would be.
    Having had a good look around the only built in double oven with pyro cleaning in both ovens is this De Dietrich model.
    Next best would the Fagor equivalent but it’s only pyro in the bottom oven.
    HTH 🙂
    Don
    #404595
    pete2848
    thanks don, do you think bosch/semeins do any double ovens with pyro just in the bottom, ive read a lot or reviews on the fagor de ovens and they all have appalling reviews on them so i want to avoid them at all cost, or is there something that i could get put in as two units that would work fill the space of my current double oven. Really appreciate all you help chaps.
    #404596
    don
    Okay then, put one of these pyro single ovens in and over it put this compact pyro oven and microwave.
    The combined height is 15cm more than a double over so a little adjusting of the carcass will be required.
    Hey presto you have a double cavity pyro oven(s) and in the brand you want.
    HTH 🙂
    Don
    #404597
    solder_on
    We have a Samsung BQ2Q7G078 built in oven that’s pyrolytic & has a removable shelf to split the oven into 2, or can be used as a single large oven.
    We think it’s the dogs wotsits.
    Hope this helps.
