I/sit AWD12SUK
  • #18571
    PGS
    Hi been to above m/c today and timer is constantly cam advancing, the customer said she had power cut and M/C was fine before that, ive visually checked pcb but coulnt see any obvious signs althopugh i think it may be the board but would like to be sure before ordering cheers Guys Paul.
    #179478
    Dave_Conway
    Re: I/sit AWD12SUK
    Is the neon not flashing a sequence as well indicating a fault code (in the known error codes thread) ? 😉
    #179479
    Re: I/sit AWD12SUK
    Get a recon board from EMW. It’s almost certain the module is the fault and fitting an EMW board will sort it I expect 😉
    #179480
    PGS
    Re: I/sit AWD12SUK
    Door lock indicater on constant, power nean flashes once
    #179481
    Dave_Conway
    Re: I/sit AWD12SUK
    Go with Martin’s advice in that case 😉
