My SMEG oven (mod: SC336WH) has a working fan but the oven only heats up with the grill on. I assume the element needs replacing. And that it’s a relatively simple job.
Does that sound about right?
Any advice on where to get the correct replacement part?
Re: I think I need a replacement element for SMEG oven
If the fan is running then sounds about right. The only way to be sure is to remove the element having first turned off the power :zap: and have it tested.
You can order a replacement by hitting on the green tab over on the right of this page 😉
don wrote:Hi
