I think I need new Carbon Brushes. Blomberg 1301ABB/Selni
Home Forums Public Support Forums Spare Parts Help I think I need new Carbon Brushes. Blomberg 1301ABB/Selni
Viewing 3 posts - 16 through 18 (of 18 total)
  • #145289
    burns
    Re: I think I need new Carbon Brushes. Blomberg 1301ABB/Seln
    WHEN FACED WITH THE SAME, THE DISPENSER IS ABOVE THE DOOR SWITCH – DUE TO LEAKING FROM THE DISPENSER BEHIND CONSOLE, IT HAD RUN INTO THE DSWITCH AND BLOWN THE BOARD, I AM SURE THE RESULT WAS NO SPIN. ON INSPECTION OF THE BOARD YOU COULD CLEARLY SEEN IT HAD BLOWN, APPARENTLY TALKING TO A COMET ENG, THIS CAN BE COMMON ON MODELS WHERE THE DISP IS ABOVE THE D.SWITCH. PRICE MAY BE AN ISSUE HERE.
    #145290
    The door switch will only blow once…… so if the appliance does actually lock and start the programme, this ain’t the problem. Have you checked for continuity through the various motor circuits? If OK, check from the top end – following the wiring back and check for continuity from the timer end.
    Is there any motor action at all? If none, the problem may well lie in the timer/controller unit. If you have wash but no spin, you will need to check the water level control system – these machines are so-and-soes for sludging up. The machine drains, but still thinks it’s full, so won’t spin.
    HTH,
    Mibol_Zaritchy
    🙄 a bit late maybe but try checking the outlet pump for blockages 🙄
