Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Iarp bar fridge help
- This topic has 18 replies, 4 voices, and was last updated 3 years, 3 months ago by
Pbutton.
December 31, 2022 at 2:50 pm #101522
Pbutton
ParticipantI have been given a corona branded iarp back bar fridge but cannot work out how to change the settings as I do not have a manual. Husband has pressed a few buttons too many and it is not getting cold enough or cycling long enough. I cannot find a similar control unit and picture is too large to attach. Serial number is 16FE89031 control unit has up/down arrow lights on the left, central number display and dot light top right and enter arrow light lower right. Can anyone help?
December 31, 2022 at 3:03 pm #485070don
ModeratorA picture would help, you can upload a photo to one of the many hosting sites and then paste it here. The model number of the unit would be very helpful as well.
I think I know how to adjust but I just want to make sure 😀
Don
December 31, 2022 at 3:20 pm #485071Pbutton
ParticipantHi thank you for your prompt reply. I have sent a link which should show you some photos.
December 31, 2022 at 5:10 pm #485072electrofix
Moderatortry holding the bottom right button for a few secs then see if the up and down arrows work
December 31, 2022 at 7:37 pm #485073don
Moderatorelectrofix wrote:try holding the bottom right button for a few secs then see if the up and down arrows work
Just what I was thinking 😀
Don
December 31, 2022 at 7:41 pm #485074Pbutton
ParticipantTried that then pressed down arrow got c1, in, ul, t6, y8 then down to y4 by pressing down arrow. Pressing up arrow made all lights flash?
December 31, 2022 at 7:53 pm #485075Pbutton
ParticipantKeep getting different display I assume Al is alarm but not sure about others
December 31, 2022 at 11:55 pm #485076electrofix
ModeratorJanuary 1, 2023 at 11:08 am #485077Pbutton
ParticipantThank you will give it a try, happy new year to you 🙂
January 1, 2023 at 6:05 pm #485078Pbutton
ParticipantHave tried resetting as per instructions by pressing up and down arrows for 6 secs but has not had the desired result. Has thrown up a new set of combinations 🙁
January 5, 2023 at 3:39 pm #485079Pbutton
ParticipantHi, I have found out it is an eliwell controller, but was custom made and discontinued so they can’t help. Can you advise me if I bought a similar eliwell control are they easy to swap and do they come pre set? Thank you.
January 5, 2023 at 3:40 pm #485080Pbutton
ParticipantNumber on controller nEW974
January 5, 2023 at 4:08 pm #485081Tony R
ParticipantAn Eliwell ID cool/chill controller will do the job, they are rated for 240v supply feed, some older units are 12v supply, you can check yours on the rating label on your old controller, if you have a 12v one you will need to bypass the transformer and wire the new controller to the 240v input supply from the transformer, ID cool very easy to set up, normally comes with an instruction manual.
January 5, 2023 at 7:15 pm #485082electrofix
ModeratorJanuary 5, 2023 at 8:05 pm #485083Pbutton
ParticipantNo it does not have a power button. It has touch sensitive buttons and the one at the top right is just a round light. It comes on when you plug it in.
