Iberna Fridge Freezer
Home Forums Public Support Forums Spare Parts Help Iberna Fridge Freezer
  • #5471
    Critical_Bill
    I was looking for some parts for an Iberna IB 28 fridge freezer. The parts I’m looking for are the door shelves, glass for the salad crisper and the pulldown drawers for the freezer. Any help would be appreciated.
    #111489
    Dave_Conway
    Re: Iberna Fridge Freezer
    Hi Bill,
    Could you check inside the fridge for the rating plate and look for a number beginning 39?????????
    There’s two versions of this model.
    Regards
    Critical_Bill
    Hi Dave,
    The number on the rating plate is 3900984 0040 0261, hope this helps.
    Cheers,
    Bill
    #111491
    Dave_Conway
    That looks like the one 😀
    I’ll check it in the morning for you.
    #111492
    Dave_Conway
    As I thought with most products, identifying these “cosmetic” parts is not easy. Can you specify the following please:
    Which position on the fridge door the shelves are you require, and whether they are full width or half width ?
    In the freezer compartment, which position do the drawer fronts fit, i.e. top, middle or bottom. Do they actually fit directly to the basket or do they drop down on a hinge attached to the freezer inner wall ?
    The salad crisper glass cover is easy 🙂
    #111493
    Critical_Bill
    Ok, the freezer drawers are for the top and the middle, so its just the fronts and not the section that fits to the basket ( seems to be the only bit that’s ok), also I will need the plastic parts which act as hinges for these drawers. As for the fridge door shelves they are all broken so I need the top, middle and bottom shelves. Not too sure what is meant by full and half width but I’m guessing it’s one full width for the milk etc. and two half width for the upper shelves but in looking at whats left of the shelves the one for milk and the upper one seem to be the same width.
    Is width the depth of the shelf or the height? I take it they must all be the same dimension side to side to fit the slots.
    Sorry for being so confusing.
    Bill
    #111494
    Dave_Conway
    Critical_Bill wrote:Sorry for being so confusing.
    No problem, if you drop me an email, I’ll let you know all the details.
    Regards
