Ice Diamond stopped working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Ice Diamond stopped working
  • #51254
    Taran_las
    Hello,
    I apologise if this question has been asked previously – I have an Ice Diamond fridge/freezer in the garage (which is not heated). Its 11 months old and on Christmas eve it stopped working. This is when the really cold weather started. A couple of days later it started again (coincidentally when the weather warmed up significantly). Due to its age I’m not sure if I should take a gamble on it continuing to work.
    My questions is – could the really low ambient temperature stop it working (and conversely could the warm up convince it to start again)?
    Many thanks for any help you can offer.
    Phil
    #307400
    don
    Re: Ice Diamond stopped working
    Hi Phil
    It does sould like an anbient temperature problem 😉 This article should help explain why refrigeration needs ambient temperatures.
    HTH 🙂
    Don
    #307401
    Taran_las
    Don,
    Many thanks for your help.
    Regards
    Phil
    #307402
    yleewolf
    Hmmm – I have an Iced Diamond RFA51P also that is defrosting in the garage. Could this cold weather be the cause?
    I defrosted it and left it for a couple of days when the problem first arose and it seemed to work ok when turned back on but this didn’t last long and I now have the high temp light on constantly and the freezer is well above decent operating temperature.
    I was going to buy a new freezer but if the low ambient temp is the cause of the problem, a new unit is going to suffer the same fate, is it not?
    Where do i go from here??
    Chris
    #307403
    spimps
    yleewolf wrote:Hmmm – I have an Iced Diamond RFA51P also that is defrosting in the garage. Could this cold weather be the cause?
    Chris
    mediteranean is not a bad bet 😉
    We don’t normally have sustained cold spells like this,couple or three days you wouldn’t notice.Seperate freezers or don’t rely on it until temps rise to 8c or so.
