Iceland Kyoto KU 127 Upright Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Iceland Kyoto KU 127 Upright Freezer
  • #75385
    shelleysho
    10 year old Iceland Kyoto KU 127 Upright Freezer
    Inside the temparature -25c at the top but only -10c at the bottom and the compressor is very hot to touch.
    Any suggestions as to what might be the problem? Thank you.
    Richard
    #394753
    Re: Iceland Kyoto KU 127 Upright Freezer
    Fan motor or not defrosted ? Try turning off with the door left open for 24hrs then restart as normal.
    Bryan
    #394754
    shelleysho
    many thanks will give it a try……..
    Richard
    #394755
    shelleysho
    Tried turning the freezer off for 24 hours but still the same, warmer at the bottom than the top
    Could it be the thermostat, the temperature is controlled by the ‘FF Max Med Low’ switch outside right at the top on the front above the freezer door.
    How do I get to the thermostat and what type do I need to replace it?
    Any advice would be greatly appreciated
    Richard
