Iceline Freezer Door Seal
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Iceline Freezer Door Seal
  • #12321
    alls
    I’ve received from Expert Appliance Care some replacement parts for an Iceline UF127 Upright Freezer. One of the parts is a Door Seal, to replace the one on the freezer which has split.
    Having a look today, it appears that the old seal won’t just pull out to be easily replaced and I don’t want to damage the new seal or be left with a freezer full of food without any seal at all.
    Can anyone help by advising the method of replacing this seal?
    #149076
    Dave_Conway
    Re: Iceline Freezer Door Seal
    It’s almost certainly not replaceable alls 😉
    Nearly all refrigeration doors are manufactured with the seal “glued in” in the factory. Oddly enough though, the seal is shown as a a seperate part 😕
    Is the unit under guarantee still ?
    Either way, you’ll probably need a whole door to be honest 😉
    #149077
    alls
    Many thanks for your reply. You kind of confirmed what I suspected, that the whole door would need to be replaced.
    It seems bizarre that I managed to purchase a new seal as a spare part which can’t be fitted. 😕
    The existing seal has a 20mm slit in it. Any idea how derogatory it is to the efficiency of the freezer or whether there is a sealant suitable for repairing it?
    I’ll see about returning the seal for refund anyway.
    Thanks again
    alls
