Re: iceline freezer question
The green light i the mains indicator,ie it’s powered up.
The orange one is the fast freeze switch,so if you are putting fresh food to freeze down in, you switch that on 12hours plus before,it bye passes the thermostat and pulls the temp down lower than normal so the fresh food freezes quicker,the quicker fresh food is frozen the better the quality.
99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} think it should be switched on after it is loaded but this is not correct,it’s too late then.
Cheers
BG
