ide 1005 not draining water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ide 1005 not draining water
  • #9052
    i have an indes#it ide 1005 that refuses to drain the water away. the warranty ran out about 6weeks ago, which was convenient. i have checked to hoses, pump and had a good look underneath and found no blockages. when on a cycle, some water does come through the hose but not very much. an error code A03 appears when it stops… any ideas? would be much appreciated, if not… what to buy next? will never go indesit again, i bought it as part of a package with washing machine and fridge freezer, all had parts replaced and numerous amount of call outs. the dishwasher was crafty enough to wait until after the warranty ran out 😕
    many thanks…
    steve
    #131882
    Hi Steve,
    It’s likely just an internal blockage or pump failure so not too expensive to have repaired. Try Repairs@ or the directories and see if any of the guys can help.
    Re: ide 1005 not draining water
    the pump and hoses seem to be clear, how much is it likely to cost for a pump? am i better getting it direct from indesit or is it something that can be found cheaper elsewhere?
    cheers,
    steve
    #131884
    Dave should be able to sort one out for you if required, just drop him a line to spares@ukwhitegoods.co.uk so he sees it, it’s easy to miss the odd thread on here. 😉
    just_steve wrote:the pump and hoses seem to be clear, how much is it likely to cost for a pump? am i better getting it direct from indesit or is it something that can be found cheaper elsewhere?
    cheers,
    steve
    Steve did you work out what your fault was – mine has just popped up with error A03 and wont start any program. How did you fix yours?
    Ed
