This is a Whirlpool DWH M10 W. Please see photographs (three links below).
Leak 2 is a slight drip only from the circled weep hole in the bottom of the plastic housing mounted on the dishwasher side. It only occurs at the end a cycle during the drying phase I think and it doesn’t cause any problem, but I am puzzled to know what causes it. Could it be condensate?
Leak 1 produces a stream of water again through the circled hole. At one stage, after I had had the dishwasher on its side, it produced an almost imperceptible drip and the dishwasher worked fine again for several washes, but now water runs out of the hole during the cycle and sufficient collects in the drip tray to activate the float valve the next time it is used unless it is mopped up first. Do you know what the cause of this leak could be please?
Photos:
https://drive.google.com/file/d/1L26E9JAjYuDove_N3zM8mPBixrIX2aff/view?usp=drivesdk
https://drive.google.com/file/d/1DCvg9aYOuxNzTm2cVZQHFKv5FeQNQqyi/view?usp=drivesdk
https://drive.google.com/file/d/16UevhmEQX2Syp-uJ1WpGqZzN1VAdKk9p/view?usp=drivesdk
OR the same photos via dropbox:
https://www.dropbox.com/s/lahm3w68fnd4evv/received_1890238617758577.jpeg?dl=0
https://www.dropbox.com/s/yvlne3cpzotn8kt/received_2135617033432997.jpeg?dl=0
https://www.dropbox.com/s/4bwyn07mmkiatpn/received_1004310309960379.jpeg?dl=0
Thank you!
