Idesit WIDL126 no lights
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Idesit WIDL126 no lights
  • #31086
    DanM
    A few weeks ago our dryer broke its belt. I submitted a post on this forum and you guys really helped me out (thanks!). Now I’ve got another
    problem that I’m hoping someone can help with.
    Our Indesit (WIDL126) washing machine hung/stopped mid-cycle. My wife turned the power off and back on at the wall. After that none of the lights will light (including the power-on light). The automatic door locking mechanism still works, so there’s still power in the machine.
    What’s the most likely cause for this failure? Circuit card failure? Transformer failure?
    In case its the circuit card, I’ve managed to remove the card. It looks like its got two edge connectors that I presume are test points. Is there any way a mere mortal can verify circuit card goodness using these connectors?
    #229626
    Martin114
    Re: Idesit WIDL126 no lights
    Quite likely to be motor o/c possibly due to carbon brushes.
    Unplug machine before checking :zap:
    #229627
    DanM
    Sorry, what does the “o/c” mean? And how do I check the motor and/or brushes?
    #229628
    Martin114
    Sorry DanM, by o/c I meant “Open Circuit”.
    #229629
    DanM
    Gotcha.
    So a electrical failure in the motor can cause the power on/off light on the front panel not to light?
    #229630
    JohnRusu
    Hi DanM,
    I have a similar problem. How did you fix yours ?
    Cheers,
    John
