Re: IDESTIT OMEGA 1200 (WDG1295W)-water doesn’t heat
Water heating problem – probably element, p/no C00044772, although these machines do suffer wiring problems at the back of the drum.
Drying problem – fan motor not running is common – motor is p/no C000562883. The duct and the condenser housing are also so and soes for becoming bunged up with fluff and preventing airflow.
Power off if investigating.
If you need to order spares, an email to spares@ukwhitegoods.co.uk quoting the part numbers will get things moving for you.
