Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › IDL 500 UK2 – Error first and second lights
- This topic has 8 replies, 3 voices, and was last updated 17 years, 7 months ago by
lgmdaniel.
September 6, 2008 at 6:16 pm #39284
lgmdaniel
ParticipantI have a IDL 500 UK2 dishwasher that is displaying the first and second lights, now I think it means the water pump is flooded but I’m not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}. Can anyone help, as at present search and the manual are giving be blank leads.
Thanks.
Dan.
September 6, 2008 at 7:04 pm #261917Penguin45
ParticipantRe: IDL 500 UK2 – Error first and second lights
No drain detected in the time allowed. Does the machine drain?
September 7, 2008 at 1:43 pm #261918lgmdaniel
Yep your correct the machine has not drained.
Should I take the water out myself and try again or could it be a blockage somewhere.Thanks.
September 7, 2008 at 3:40 pm #261919lgmdaniel
Thanks, based on the fact that it would not drain I pulled all the pipe out and found the u-bend on the drain was lime-scale city. So pulled it all off and cleaned it all out, thanks for your help.
September 7, 2008 at 4:51 pm #261920lgmdaniel
Spoke to soon, its not pumping the water away, so new pump needed I think.
September 7, 2008 at 7:33 pm #261921Penguin45
Possibly just blocked……..
September 24, 2008 at 1:22 pm #261922lgmdaniel
Good point, I will have to take the back off and have a look. Can anyone direct me to some manuals maybe for this model?
September 24, 2008 at 3:28 pm #261923iadom
ModeratorRe: IDL 500 UK2 – Error first and second lights
Specific manuals are not generally available.
Remove the mains plug, place some towels on the floor and tip the machine onto its left hand side looking from the front.
Remove the base plate, making note of the position of the wiring plugged onto the float switch.
Follow the grey plastic pipe into the machine and you will find the drain pump. Protect the wiring below it as you remove the hose and pump.
September 30, 2008 at 9:34 am #261924lgmdaniel
Thanks for the advice, I’m looking to move house next month to might leave it till then, as there will be a garage so I can get it done outside.
